Go Pros at The Blast !!
If you are using the old Go Pro at the weekend put the setting on 3 ( 720@60 frames per second ) and send your best few seconds to me, I will forward them to my friend who will edit them and make it viral and make it even more famous..
I met a Kiwi the other day who had heard of me in New Zealand !!
Richie
Will do, why 60 fps? full HD (1080 and 30 fps) gives much better picture. The files tend to be huge tho.
I have no idea !! the scienceonomist who made the suggestion will have to be consulted but I suspect you answered your own question !! Lucky for me I have **** all else to be doing !!
I think you answered your own question there Andrew :)
Anyone not doing the Blast who has a go pro give me a PM, I will gladly put one on the lid. And dont worry bend it you mend it, break it you buy rule applies!!
[QUOTE=Byrner;125604]If you are using the old Go Pro at the weekend put the setting on 3 ( 720@60 frames per second ) and send your best few seconds to me, I will forward them to my friend who will edit them and make it viral and make it even more famous..
Richie[/QUOTE
sheep shaggers in NZ that's why
if you spent as much time digging as passing snidey comments we would have two Blasts courses at this stage !!
60fps is better when there is lots of movement, you just need to go faster andrew to see the difference!. the end result will be mainly viewed online so 1080HD wont matter much, as the footage is usually converted back to 720.
now just do what you're told FFS.
i've been away working so sorry but that's just the way it goes.
if you had the blast in the city centre or in Roscrea or ..... then sure i'd be there.
anyway i'm crap at digging.
I'll be running 2 cameras, rear and front, at least that's the idea, both will probably get knocked off in the first 50 yards!
I'm dressing up as Luke, I have the blk curly wig, the hot pants and the fat arse. I have the accent down to a tee. " I drive a Beemer yah" see.... deadly!!!!
Originally posted by Don View Post
Just remember to switch them on in time this year!
ah - yes, good reminder Don, I need to remember they're only the basic ones without the "mind-control-switch/auto-pinning-it-detection-power-on" technology
Richie
Richie[/QUOTE
