Once again its race prep time for an XC race..hahahaha..some of you made stupid, stupid mistakes last time so heres a refresher..
A Powerlink..use a piece of insulation tape and tape it to your front brake hose.
Get a teeny saddlebag and place it securely under your saddle with a tube and a couple of CO2 canisters in it.
Your Jersey will have 3 pockets.
In the middle pocket put your inflator and if you have any sense a decent mini pump.
In one of the other pockets put 2 Gels, make sure you have tried and tested them though.
In the other pocket put a bag of Powerbar Jelly yokes.
You do not need a Camelback
You do not need a fookin rainjacket, long sleeves or thermals !
slide a High 5 gel up the leg of your shorts ! it should stay there till the end of lap 1 , then stick it in your gobs asap !
You do not need armour , end of story !
Check your bike..its not race ready if the end of the gear cables are missing the nipples..if the nipples are missing replace the cables immediately.
Do not use schwalbe tyres ..do not !!
Check your jockey wheels..
Leave nothing to chance..if you dont have time bring it to a bike shop immediately !!
Visualise crossing the line in first place
Wear very tight underpants/knickers for the next 3 days
Get your bike set up just right tomorrow and fix it immediately if its acting the maggot.
bring 1 500ml bottle on your bike and leave 2 in the feedzone
Use a bottle with flat coke for the last lap..oh yeah..that will fire you on something miraculously !
Check your grips..are they loose ? are they worn ?
Visualise victory and pay attention to Conan , and check out myself when I had hair and a beard as his coach !
no Camelbacks and 3/4 length baggies..its not a feckin picnic.
you don't need tyre levers..use the end of your skewer !
Remember too that you can't recieve help from non competitors except in the feed zone but if you get in to trouble out in the course you can only recieve help from your club mates !
Most of all come back on the interweb afterwards and praise David Furlong and his merry men for a most excellent race !
WHatever you do , dont lose !!
http://www.youtube.com/watch?v=NzgU5O-3Xto
Excellent !!
Excellent !!
