Just letting you know I will be updating the forum at some stage over this week so if for some reason it's down when you log on don't panic.
I'll be doing this during off peak hours so ideally you won't notice anything.
Adrian
For those interested the update includes these changes
Adrian
Change log for 4.2.1:
- VBIV-15679 Add IE9 Meta Tag to VB 4.2.1 headinclude template
- VBIV-15639 " " is returned instead of actual quotes
- VBIV-15638 Activity Stream displays m-D-Y h:i A instead of actual date value
- VBIV-15620 4.2.1 A1 has no GMT +0 option in the timezone settings
- VBIV-15604 Syncronize Bitfields with vB5 to prevent future clashes
- VBIV-15523 Reflect COPPA settings in API responses
- VBIV-15425 Blank entries in Forum permissions screen
- VBIV-15404 Navigation Manager - Pull Down Menu Tabs - other links etc do not display nor does Tab highlight when on THIS_SCRIPT related page
- VBIV-15401 Dropdown arrow on tab dropdown menus is poorly positioned
- VBIV-15389 Product export does not have tab with menu pull down XML field
- VBIV-15386 User profile activity stream Friends tab ignoring privacy settings for friends
- VBIV-15371 templatestofiles.php fails on bootstrap load.
- VBIV-15368 showthread message formats are missing/incorrect
- VBIV-15366 forum.php contains corrupt copyright notice, causing errors on some sites
- VBIV-15353 Activity Stream CMS Widget
- VBIV-15341 Custom user profile fields don't work correctly on registration with mobile style - missing mobile template: userfield_select_option
- VBIV-15339 apitextformat not working
- VBIV-15336 login_facebook always returns "badlogin_facebook"
- VBIV-15330 Clicking any CMS url loads the front page in IE8
- VBIV-15327 call to activity is returning different JSON object graph for albums
- VBIV-15326 need thumbnail URLs for attachments when calling activity
- VBIV-15325 Upgrade crashes on 4.1.10 Alpha 1 Step 3
- VBIV-15318 register_fbconnect does not return values specified in docs
- VBIV-15317 api_forumlist is returning empty value in API v7
- VBIV-15312 Default URL to link to "My Blog" not working in navigation manager nav links
- VBIV-15301 article node id not included in call to activity
- VBIV-15300 Doublepost Default phrase is missing Size 1
- VBIV-15291 PostRelease doesn't work correctly if admin cp is not in the standard directory
- VBIV-15289 HTML data being prepended in all MAPI responses
- VBIV-15280 QA Task - Verify Updated Template/Phrase/Navigation Version Number (4.2.1)
- VBIV-15273 Database error when transferring group ownership, but transfer succesfull
- VBIV-15271 Redirected threads are always marked new
- VBIV-15266 Reputation given bit link doesn't link to the post
- VBIV-15254 call to "activity" always returns error
- VBIV-15239 If you are running PHP 5.2.0 or 5.2.1, an error in the Navigation Manager kills the site
- VBIV-15238 Blog Bug When Deleting Spammers
- VBIV-15236 Wrong function used for error message
- VBIV-15221 register_fbconnect returns empty value
- VBIV-15219 Session url is defeating the anti looping code.
- VBIV-15217 Default batch size is too small
- VBIV-15214 The special characters shows up as HTML entity codes (ÿ) when calling showthread/newreply_newreply
- VBIV-15206 Unescaped dash in is_valid_email() function allows emails with illegal characters
- VBIV-15205 Redirect error ("Loop") with content.php as Default Tab since vB 4.2.0
- VBIV-15204 PHP Memory Limit doesn't show up in AdminCP due to typo in /admincp/index.php
- VBIV-15190 Moving posts results in datatbase error
- VBIV-15182 Typo in options_options_wrtlimit_text
- VBIV-15175 Flood protection does not work
- VBIV-15169 Deleting the default tab results in no tab being set as the default
- VBIV-15165 Uninstalling CMS fails with DB error
- VBIV-15164 Duplicate post prevention bypassed by doublepost automerge
