I noticed a light vibration through the bars the other days since I put on a new Ignitor, I think my front wheel needs balancing, any idea who can do this?
Where can I get my wheels balanced?
WTF You are surly having a laugh now Don, arn't you?
If you have any mechanical ability you can easily do this yourself. You can buy the appropriate balancing weights in Halfords. Start with a 5g weight on every second drive-side spoke and work from there.
Noooo.... Morgan, that is the old way. It adds too much weight.
Don, spin the wheel, and when it stops, the bottom is the heavy point. drill a hole here and repeat. keep drilling until it just stops randomly. you will have to replace the tube aftre, or buy 31 patches. easier to change the tube.
should look like this
http://farm4.static.flickr.com/3096/...e6d289331d.jpg
Originally posted by Fat Fecker
View Post
The rim looks like one of Kev Coughlan's bored-of-an-evening weight saving measures. The same approach can be quite effective with other parts of the bike like seat post, stem, bars, even strategic parts of the frame. Not recommended for seatstays.
you forgot fork lowers, handelbars, tyres. Anything can be drilled if you do it right, just look at one of the wolfes bikes! More holes than a russian prostitute!
Originally posted by gregc
View Post
I do recall Ger Wolfe taking the grand tour of Alpe d'Huez looking for a cordless drill!
Good one Gaz. Her name looks oddly like a Welsh placename though!
What like this one
Llanfairpwllgwyngyllgogerychwyrndrobwllllantysilio gogogoch :)
She has a friend with three balls too called 'Whojanickabollockoff'
Cheers lads, I will try all of those suggestions, or rotate the tyre to the rear were any worn bushes may counteract the imbalance.
Gary, you can no doubt say that name perfectly when drunk.
If I remember rightly there's a station on the Fairbourne "railway" with a name even longer, they deliberately made up the longer name to outdo Llanfairpwllgwynhowaya. Sad or what?!
Best thing about the Russians is that meerkat ad.
I used to live in Fairbourne for a couple of years, i worked in the forestry above the Blue Lake for a local land owner, brilliant for biking, had my own little DH trail right from the top of the Garn to the bottom, right on to Friog road, about 3 miles in total with only one tiny bit of up hill, it was brilliant.
