Lend of a Garmin for a day or two
Looking for a lend of a Garmin for this Sat. Needs to be one which you can upload maps, I have a 305 but it doesn't have an upload function.
Cheers Culchie........are you sure you can upload routes into it and follow them with the onscreen map? iv a 305 which I assume is the next model up but doesn't have an upload function.
I'm fairly certain, I've loaded a couple of Richies routes on to it and it worked no bother. I'll double check to be sure. It only has the breadcrumb map though which I think is the same as the 305.
I just checked there and I've definately been able to upload an external route to it. It doesn't have the picture map layout(I don't know what the correct term is) though, just the breadcrumb layout.
Where are you based during the week, I can drop it off to you if you need, I don't know if I'll be around for Thursday night.
