Tubeless conversion
I'm looking to convert to tubeless using Mavic Crossride disc and 2.1 Ignators
Is it possible?
What is the best kit?
Are there any major pitfalls?
All advice and comments welcome and thanks in advance for the info!
utube it till you find a chinese guy in a garage
he has it sussed.
compressor is handy as can be nightmare with even a track pump
In my opinion (for what it's worth) I would use UST tyres for the 1st attempt. UST Ignitors will seat with just a track pump no problem!
If the tyre goes over the rim easily when you are mounting it, it will be difficult to get the air to seal, even with a compressor. I have found ignitors are larger in diameter than swalbes (same rim) there must be some tolerance in diameters of tyres so not all will be like this. just expect it to be hard to inflate if it goes over the rim easily. Tubeless tyres are easier as they are stiffer sidewalls. If its a foldable tyre, unfold the tyre the day before you mount it so it returns to a round shape and you dont have 8-10 kinks on the sealing edge.
Thanks for all the advice lads.
I couldn't find the youtube chinese guy!!!
My synapse is that, I need a kit and UST tyres!!
I was hoping to get away with just buying the kit, as the ignators are new-ish (4 months)
What next?? :confused:
you don't necessarily need UST tyres ! get the kit and try to set it up with your current non UST Ignitors... quite a few people run non UST tyres tubeless.
(because they are lighter and cheaper)
